I recently bought a 1985 1860 with a 70 hp evinrude knowing the boat would need some work. The boat sat for 2 yrs before I got it. The motor originally had VRO, but it has been removed. The engine was gone through before I got it by a mechanic. I have made progress in geting the motor to run right, but it still wont run under load. It will start fine and idle good the first try. When in gear, it will go about 5 mph and die out when you drop the throttle down. It will then get tougher to start back progressivily. It eventually will only run with full choke and stall when put in gear, then it wont start or run until you let it sit a few minutes.
The motor came with an electronic fuel pump that was not attached. It had been installed by the owner two before me. The guy I got it from said his mechanic said it did not need the pump, so he took it off. I dont know if it was run in water after he pulled the pump. I saw it run on the hose pipe.
Here is what I have done:
I put new fuel line from the tank to a brand new Mr. Gasket electronic fuel pump 5-7 psi. I put an open connection on the tank (not the barb kind) and attached the line with hose clamps. The hose did not fit tight to the connector, so I tightened the clamp down as hard as I could without breaking the clamp. I have the same connection going into the pump filter and out the other side of the pump. The motor connection is brand new and the barb style. From tank to motor my lines are 3/8". From inside motor to carbs the lines are 1/4" then drop to 1/8" as it branches to the high and low jets on the carbs.
I also pulled the carbs and cleaned them. They had new gaskets on them and the floats looked good. I sprayed out the jets with carb cleaner. I set the bottom of the floats to the top of the bowl by eyeball.
I also put a new set of spark plugs on it. Compression is 140 on all 3 cyl. Spark is good on all cyl.
My Plan:
I have ordered 3 carb kits w/o floats. I am going to replace the jets and gaskets to be sure. I am also going to replace the fuel lines from inside engine to carbs. While in there, I am going to check the reeds on the manifold. I forgot to do that last time.
Question:
1) Do i need 3/8" line from tank to motor if it stepping down to 1/4" inside the motor anyway? I can get a better seal on a 1/4" by changing the fittings.
2) What would the motor do if I had a bent/ broke reed?
3) I am thinking it is not power pack or timing because it idles good at high and low. Is this correct?
4) my pump is around 4-7 psi. Is this sufficient or too much?
5) How precise do the floats have to be to run right? Will a 1/16 or 1/32 difference between carbs make it not run right?
6) any other ideas would be greatly appreciated.
thanks,
mike
My Plan:
Question:
thanks,
mike
