water out of through hall exhaust
TheToad
first info on the problem. pachanga 22, 454 gen4, florida marine headers and exhaust. i just built this motor and ran it on land to set timing and such. when i put it in the water i am only getting water exhaust out of one side at idle, i get water exhaust when i pull rpms but it dosent seem to be as much. any idea what would or could cause this?
i included a picture of my boat.
legoman67
Re: water out of through hall exhaust
how is it plumbed? some have a Y pipe and equal split of water, some have the water to into one riser and then from that riser to the other.
The second design, by design will have more water flow out of one riser then the other, but you should still get water out of both at idle. If you dont either your pump impeller is shot, or your pump is not sufficient for your setup. or its possible theres a kink in the line somewhere....
What temps are your risers running at?
Ayuh,... You were feeding the impeller with water during this time, Right,..??
How long ago was the impeller last changed,..??
TheToad
its set up with a Y housing. impeller was just changed thought that might have been in issue so we knocked that out right off the get go.
legoman67
since i dont know your location i have to ask, does the boat run on salt water? if so how long ago did you last replace the risers?
TheToad
fresh water never seen salt.
Philster
Do you have a t-stat in place? If so, what temp?
TheToad
You need an IR gun and measure the risers directly. Are either hot to the touch at idle?[/QUOT]
at idle they are i warm never hot i can always touch them at idle.
TheToad
well thats the case it runs o.k i'm just worried about the uneven water flow. alot of people question it but have no idea why it does it.
nofuss
just a little hint, with boats if something looks wrong something probably is, more likely than not. Check the hose that carries the water to each riser, You may even have to take it off, start the engine briefly and see if water flows through each easily. messy but easy check. if the same amount of water comes out each side, then there is some blockage in the riser. if not there is something amiss before this point.
trouble shoot it this way and ensure that u check everything, dont just assume that all is well and end up shut down or limping home with expensive damage that could have been avoided by a couple hours of checks.
if there is an equal Y then the water flow should be about equal, unless there is some reason for a difference. ensure the reason is design and not blockage.
TheToad
this is mine without risers
It is very normal to have more water going out one side than the other...especially at idle.
