dayfloater
Thread starter- Joined
- Jul 18, 2010
- 9
hello all and thanks if you respond well its been a rough day a float but it wasnt too long before help towed us back to marina, before all this boat was doing fine took a short break in a cove when we went to leave put it in forward gear and heard a loud pop, now that we made it home safely from what i can see the main engine driveshaft isnt turning
forward/reverse is this a hard fix? what has to be removed engine or outboard im lost, boat is a 1985 galaxy mercruiser 190 4cly 4bbl inboard/outboard UPDATE i removed the outdrive thingy/unit splines are wiped out on the engine side what is this part called? i assume its like a clutch but im not sure any help with this issue would be great
