I have a older Honda B100L motor. Last time we had it ran till we shut it off, but that was 10years ago. I brought it home, New plugs, oil in the cylnders it was stored inside. Bought a new gas tank cause the old one was full of rust. Put some fuel in, Pumped the bulb. Gave it a pull and a pull and so on and so on. It fired a couple times but didn't run. Took the cover off and pulled till I was blue face
. I didn't get mad. I expected this to happen. But during pulling and pulling. The belt that runs to what I presume is the cam for the top end broke. and it feels like I have no compression now. The pully seems loose and sloppy and spins by it self without spinning the shaft in the centre. What is it and it being loose is it normal? How do I fix it? Did I through everything out of time?
Please any advice would be great.
Thanks
Thanks
