Roger Schweitzer
- Joined
- Jul 2, 2010
- 17
1973 115hp model #115393m rude. PO removed air silcencer cover, motor seems to run well, How ever I`m concerned about a hic up starting a fire, or the vacume (pick up lower carb port side not operating correctly) Does anyone have a spare they would consider selling me? Also I need to replace the water impeller. This motor uses the old style barrel shift connector. Do I need to unscrew the connector as I lower the bottom end? I believe the shifter shaft with the connector attached would pass through the pivot shaft, but after going that far it somehow needs to be removed so that the shaft can pass through the lower exhaust housing. Thanks for any information Roger
