Well my quick weekend bilge-pump install project turned into a total re-do of the floor. All the foam above the floor was ok, anthing below it (including the floor itself) was completely soaked and rotten. (it appears a previous owner had a fish finder on at one time that was removed and the holes never filled). Once I got the floor off, it looks like when the 2 part foam was installed at the factory, some leaked over into the center chamber, which blocked all drainage flow to the plug hole on one side. The other was a partial blockage.
The center stringer was completely wrapped at the factory, so that is still good, the other two were only partially and are now missing. I want to only have to do this once, so should I go with something pressure-treated and then wrap them, or would wrapping regular wood be sufficent? I've read where pressure treated will react with aluminum, but what about fiberglass?
Also, while I have it all apart I would like to install a center floor locker. Anyone have any ideas or suggestions?
The boat is a 1980 17 foot imperial tri-hull with an 85 horse chrysler.
Here's a quick pic I shot with my cell of the current status of this project.
