2007 Q6SF Bimini Hardware
mccownk
Re: 2007 Q6SF Bimini Hardware
What hardware are you looking for? There are multiple online resources to choose from. Including IBoats.
wkbutler
Yes. I've looked on Iboats.com and many other places as well. Can't seem to find exactly what I'm looking for. Not sure what kind of bimini you have (if it is the same as mine). Basically, one of the 'jaw slides' along with the quick release pin that locks into the base fell off into the water. I need both pieces.
mccownk
Post a picture of the remaining part that did'nt fall in the water. (I hate it when that happens) In the meantime, check Overtons.com
rdhawk1950
I believe that I would go straight to Bass Pro /Tahoe customer service. The Bimini would be a DOWCO Brand. What happened was prior to three years ago when the hardware was being installed, the nylock nuts furnish with the install kit, were not being used for the install. Warrenty/ Customer service may be able to accomidate your needs at little to no cost.`
wkbutler
Thanks for the replies. I just went thru the Tracker dealer.
