My 1996 little engine quit this weekend. Definitely a starved for fuel problem. When I pump the bulb the bulb does not get hard and i can't feel fuel flowing through it. when i disconnect from the motor connector and press in the bearing and then pump the bulb I get fuel. reconnected everthing and disconnected the hose right before the fuel pump and got flow, reconnected and pulled the hose right after the fuel pump and get flow. connect everything up and pump the bulb and simular to the roiginal problem, basically a dry bulb. Where do i go from here? thanks BTW the fuel is coming from a racor filter separator and seems intact.
