alpha one oil
shaenjay09
what type of oil do i use to refill my lower unit? its an alpha one mercruiser.
Don S
Re: alpha one oil
It's a 75/90 gear lube ....... 10W30 is motor oil. But it is used in older Volvo single prop drives, but not in Mercruisers
Get the Merc Hi Performance, it also has additives to keep water in suspension so if you do have a leak, the gears and bearings don't set in water only.
Bt Doctur
Re: alpha one oil
Make sure you fill it from the bottom untill it comes out the top hole
HT32BSX115
Re: alpha one oil
Howdy,
You can also use Amsoil Marine gear lubricant which (according to Amsoil), like Merc HP gear lubricant, is designed to continue lubricating when contaminated with up to 10% water. I don't sell it and am NOT an Amsoil cheer leader. It's just another synthetic gear oil for drives.
A local Napa Autoparts place sells it and it's easier for me to go there instead of driving further to get the Merc HP Lube.
Cheers,
Rick
Beefer
Re: alpha one oil
Ditto on the Quicksilver High Performance. Don't go to Wally World, they carry the Premium, which is not what everyone here recommends (why, I don't know, but I listen to the advise here). And you'll need 2 quarts of it.
achris
More fish than mountain goat
Re: alpha one oil
Here's a list to start you off...
Shear strength
water resistance
additive package
temperature tolerance.....
Need I go on?
Merc recommends High Performance for their equipment. So that's what I use....
Chris.......
otterby
Re: alpha one oil
I have an '88 Alpha One. I believe thats a series one. Anyway the manual and the mechanic at the marina says the drive takes one quart of oil. When I fill it it takes about 1.25 quarts. Is this correct?
ziggy
Re: alpha one oil
yep. that's right.... a little over a qt. fill from the bottom till it runs out the vent hole with the drive level..
i use the hp mercruiser gear lub too.
