Coastal Rick
Thread starter- Joined
- Feb 14, 2010
- 30
I was looking at my outboard and there is a screw on the lower unit with "flush" marked on it or next to it on the LU case. In the manual or the expanded parts diagram I've seen it referenced as an attachment point to flush the outboard without running the motor. Some kind of attachment goes there and i suppose a hose goes to that. I always have lots of trouble getting the flush cups to pump enough water - I have to squeeze them tight or water stops running out the telltale - so an alternative would be nice.
Anyone know if the parts are available, have you used it or heard of it being done, does it work? I'm running in saltwater about half the time so a post-run flush is typical. Thanks.
1973 Merc 20HP s/n 3674653
