1970 Evinrude Triumph 60 Horse, oil leak
kleons
Good Morning,
I have two issues:
1. Lower unit oil is milky.
2. There is, what appears to be, a small amount of outboard oil dripping from my engine when I pull it out of the water. I don't see signs of the leak above the lower unit.
rayodunne
Re: 1970 Evinrude Triumph 60 Horse, oil leak
Get a seal kit for your lower unit. You will need 1/4-20 threaded rod and a harmonic balancer puller to get the bearing carrier out to reseal. If you have a manual it will help you do this in no time.
kleons
Which manual is the one I should get?
rayodunne
Original evinrude or johnson. You can get them on ebay at a resonable price.
kleons
Thanks for the the book link. It has been ordered.
I'm a little unsure of what a 1/4-20 threaded rod is.
As for the harmonic balancer puller, are there special ones for outboards/marine engines?
Wingedwheel
The Harmonic balancer Rayodunne is talking about is your typical chicken foot gear puller(looks like a chicken foot)
kleons
Thanks for all of the help.
Do I need to remove the gearcase in order to replace the sealkit?
Wingedwheel
Your only problem will be removing the retaining ring that holds the bearing carrier in. Thats why you need the manual. It will have step-by-step instructions and make your life sooooo much easier.
