Jim Marshall
Thread starter- Joined
- Oct 14, 2007
- 172
My boat motor has a Jabsco rubber impeller pump. I guess that is about the only way to go since they sit above water in the engine compartment and they self prime well, that is if they don't run dry.
I only had problems with a rubber impeller pump once. It seems like they seize up when sit over the winter. There is a period of time before they catch prime that they are running dry and can shear the blades off.
Is there a good way to winterize the pump so that this doesn't happen. I have even thought about installing a brass sleeve in line that I could tap and plug to introduce water or soapy water.
Jim
Jim
