1993 tigersharks
IndianaRavenOwner
Hi all just helping a buddy who just got 2 of these ski's.My question is ..On the rear jet drive assembly there is a part called the bladder that looks like an acordian.His is cracked on both skis and when i pumped it milky oil came out of the crack in the side of it.What is this thing and is the milky oil a bad issue?We have plenty of time to fix these right and ordering parts is not a problem but just wondering if there is some lube that has gooten watered down and now needs replaced or is it normal.
Any help would be appreciated a bunch since we are both plain newbies when it comes to ski's.
lynnboy021
Re: 1993 tigersharks
you dont need it just cap it off. i think only suzuki has the bladder so someone on this forum told me to cap it wich i did and it works fine......
IndianaRavenOwner
Thats good that we can just cap it off..But is there some kind of lube in there that might need replaced since im sure some moisture has gottin in there hence the milky oil stuff coming out?
lynnboy021
that i really dont know i am rebuilding my motor and it did not have oil in it so i am looking at the manual right now
IndianaRavenOwner
looking at the exploided view in the manual there are bearings and such in there so i would think that there is some kind of lube in there..
lynnboy021
right did you find anything on what lube to use
IndianaRavenOwner
Never found out if there is lube in there to start with lol.Im hoping someone on here maybe knows if there is lube in the jet drive assembly on this thing..:confused:
lynnboy021
yes you have to take the endcap off and put in 90w gear lube
