new boat need help
tylor2009
i picked up 87 i think an has the 2.3 or 3,0 4 cylinder motor it has cobra omc out drive it pulls hard to the right if u let go of the wheel what could cause this?
jtmarten
Re: new boat need help
Anode tab adjustment, bent prop, maybe just normal torque steer.
tylor2009
only thing i seen is the guy hit something with the blade an he took a grinder on it an grinded the blade on every fen at the end so its kinda square at the ends of the blades i will try posting pics later but do you think this is whats causeing it to pull to that one side?
Don S
No, do not start grinding on the prop. Adjust the trim tab on the outdrive that is just above and aft of the prop. That's what it's there for.
tylor2009
no i didnt grind the propeller the last owner did. what is the trim tap on the out drive how to adjust it?
jtmarten
I'd try a different prop before anything else. I tagged my port SS cleaver on a rock earlier this summer and folded over about 1/2" of one tip, slightly bent the other 2. Boat pulled HARD to the left after, and suprisingly no vibration from it. Much larger/heavier boat. Doesn't take a large defect in the prop to have a large effect on the boat; small cause, large effect.
