Bottom Line Help"
Status
Not open for further replies.
GBRJ
Hello I have just aquired a Fairly new Bottom Line Tournament Master NCC 5300 Fish finder. The only problem is the GPS connector has been cut off. I have no connector. I am trying to solder pins on the wires to get it to work but i do not know where the pins go.Does anyone have a Manual or wiring diagram that would help. Any other help would be greatly appreciated...
GBRJ
Re: Bottom Line Help"
Thanks For the manual Rick. I do have the Tournament Master NCC 5300,but the one you sent will help. I have contacted Humminbird and they could not help with wiring diagram.And they have no parts at all.I am trying to locate complete reciever,Or wiring scymetic. Thanks...
RickJ6956
I don't know how I managed to link to the right manual yesterday and now it's showing a different unit. The 5300 isn't even listed!
GBRJ
Thanks anyway Rick, Without pin locations i am lost anyway. Does any one know where i can get a new Receiver by chance.I am looking for A Garmin model GPS 36 Part# 011-00208-00 Or Bottom Line Model 013064 TBL GPS Receiver. I have looked all over the internet. Have talked with Garmin,and Humminbird. I missed one on E-Bay that sold before i new i needed it.Humminbird said they retired this model and they have nothing for it.Not even the wiring help i need. Any advice is greatly appreciated......
Fl_Richard
I can tell you this - The garmin GPS receiver is a GPS receiver that spew's it's data through a serial connection to the display. Knowing that the pinout should be pretty easy to determine with a voltmeter.
There are probably only five pins. +12volts, ground,tx,rx,shield.
12 volts should be easy, ground should be easy, shield should be easy and if TX/RX are reversed just switch them.
GBRJ
Thanks, OK Now i have 9 wires comming from the receiver,, Red ,, Black,,Blue,,Gray,,Green,, Yellow,,white,,purple,,{and a bare wire is this one the shield?} It appeared to me the wires that where cut Where Red,,Black,,Gray,,yellow,,Blue. But i am not sure of this they were the only wires visible at first,, When i trimed them back so i could work with them i found the other wires. green,,white,,purple,, and the bare wire. Can you give me any help from there or No??
Status
