fordsforme
Thread starter- Joined
- Jul 22, 2010
- 4
i traded for a 1987 celebrity cuddy has fresh 355 mercruiser was running and has lost fire .im new to inboards .i was told to replace the sensor inside the dist and i have but im not sure the wires are in the right places .the guy i traded with had the wires taken loose from the coil and the sensor when i got the boat, he said it just qiut on the lake and had to be towed in and lost fire to the plugs .where can i get a diagram of the ignition setup,there are two purple and two grey going to the coil two black and there are a white with red and a white with green on them not sure where they go .the factory wires are colored the same so i pluged them together but not sure if this is correct,advice and a diagram would be helpful. thanks
