Mercruiser/Mercury lower unit swap
mattsmall1972
Hi,
My brother has a 1995 Black Max 200 Hp outboard on which the lower unit has gone bad. I have a 1970s Mercruiser 470 with (I think) Alpha 1. Is it possible to swap out the lower unit on the Alpha to the outboard?
Thank you.
Faztbullet
Re: Mercruiser/Mercury lower unit swap
No.....Even if you could the gear ratio is different
Fast, I know the driveshafts are too short on an Alpha, but could you change that and bolt it onto a V6 Merc OB?
Faztbullet
Dont know if rear stud pattern is the same on I/O vs O/B so cant say if it will bolt up and most of the I/O lowers are close to 1:1 ratio.. if ya wanted to go fast on a lite boat you might rig something up to make it work..
