woodboathull
- Joined
- Sep 18, 2009
- 25
RDE 19 1957 Rebuilt carb and fired up. Runs better since carb rebuilt, but seems to "run out of gas" Is it possible that the manifold is not pumping the tank with pressure? It seems to keep running if I pump primer regularly. After I disconnect tank, there is no "hiss" when I loosen the cap. I read somewhere that this should happen. Is there a way to check to see if motor is "pressurizing"? How about testing the tank to see if it is holding pressure? I have rebuilt the tank. I am thinking about switching fuel system to single line fuel pump, but was hoping that one of you would have some ideas. Thanks in advance.
