Trim Pump Stalls at end of Travel
dg512055
Is it normal for the trim pump motor to nearly stall to a stop when the drive reaches its full up or down position? I thought maybe there should be a relief valve of some kind in the system. My trim system works perfectly in between, but I hate to hear it bog down at the end of travel.
Alpheus
Re: Trim Pump Stalls at end of Travel
No. You should have a trim limit switch to shut pump off at max up and down travel. It should be overridin when the trailer switch is used...
Don S
Yes, it's normal. But you also shouldn't let it set like that. When you get to full up and the pump bogs, then just a brief bump of the down takes the excess pressure off the system, and prevents the relief valves in the pump from jamming if sitting for a while.
dg512055
Thank you for all the input folks. Just to clarify, the trim-up limit switch does stop the up trim. The trailer switch works also and over rides the limit switch. I never thought about letting it sit for long periods with excess pressure on the valves. I will take your advice and relieve the pressure before storage (during the week or overnite).
Thanks
Don S
Get in a habit of relieving the pressure every time you put the drive up. Your VERY EXPENSIVE trim pump will thank you for it.
