1987 40 HP Jhonson, new foot seals
jmfountain
I have remove all bolts holding foot to shaft, the foot droped down about an inch, and will not come off. Please tell me what is keeping it from dropping all the way off.
Thanks everyone, I will see if it drops off tonight
wilde1j
Re: 1987 40 HP Jhonson, new foot seals
You have to disconnect the shift rod.
mikesea
It located under the bottom carb,it has a 3/8 head with a slot for screwdriver as well
jmfountain
I don't see how to disconnect it, can you tell me where it disconnects at.
jmfountain
Thank you for the info, I know some had a side plate on shaft that you removed and losened a coupling
