I have a 1982 Sea Ray 197 with a Rochester 4bbl on a 5L v8. I bought this boat about a year ago and have been slowly fixing it up. It ran when I bought it and I have used it on occasion. I recently sent the carb off for an overhaul and when it came back, the boat ran but the carb flooded the engine. I removed the carb and sent it back to the shop. In the mean time, I pumped some gas out of the tank on the carb side of the filter for inspection. The gas looked clean and free of water. The carb came back from the shop and when I installed it, it continued to flood the engine. I removed the carb a third time to go back to the shop. This time the mechanic said he was going to order a new float for the carb. When the carb came back I decided to use another gas source with fresh gas and a new filter. The carb worked fine this time. The mechanic had told me that the problem could be in my gas tank. So the question is: Can visually clean gas that has been filtered foul the carb? Pulling the gas tank on this boat is a major ordeal. Or, was the problem in the carb float all along? Any ideas or suggestions?
