FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Re: replacing impeller on 1991 Suziki 40HP 2 stroke
Put the motor in gear, losen the cluth rod connector, loosen the lower unit bolts (with care and lotsa WD40) drop the lower unit ... replace impellar .....
best I remember shift into reverse makes it easier, DO NOT pull the shift shaft up far enough to disengage the clutch.
from there its a matter of removing the bolts and dropping the case then removing the pump housing.
