1989 merc 80 hp rectifier
jasona
Hi All,
I have a 1989 Merc 80 hp 3 cylinder, serial # 0A752169. My Rectifier is bad, so I am going to replace it. I was looking at the wires connected to it and there are as follows:
top post: labeled alt, has two yellow wires connected to it.
middle post; labeled tach, has one grey wire connected.
bottom post: labeled alt, had two yellow wires connected to it.
shouldn't there be a red wire connected to it somewhere? If so, from where does that red come from?
Thank you for the help.
jasona
Re: 1989 merc 80 hp rectifier
One more thing...I am going to replace this rectifier with sierra #18-5707, which I believe is the correct replacement part.
achris
More fish than mountain goat
In this drawing 'j' is the rectifier, and yes, that is the right sierra part number.
attachment.php
jasona
thanks achris. where did you find that diagram, it's not in my clymer book.
based on your diagram, i should have a red lead coming from "I" which I do not have right now. I will need to look so what mat be mis-connected. basd on your diagram, everything els should be ok, right?
achris
Those clymer and solec manuals need to be banned from sale!!!!! :mad: :mad: :mad:
Download a genuine manual HERE, password for the file is <ribforum>. I use 7-Zip to decompress it.
Chris.........
jasona
thank you. i will let you know how it goes.
