Re: 87 sea ray with 3.0 mercruiser dies in gear
The shift interrupt switch IS working, that is why it dies. Either the shift cable is bad, or the shift shaft in the bellhousing is binding, or you have a drive problem.
The shift cable is the most common problem. And YES, you replace it, it's binding, and they don't just get out of adjustment. They wear out.
Do a search of this forum for "Shift Cable" and you will see what I mean.
