FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Hi, iam new here so if do anything wrong sorry.I just got a 1977 evinrude 115 hp 115793s.There is no key to start but before i get one i want to try to start.Is there a way i can do this ? Also is this engine a 50:1 premix ? Thanks John
On the front of the key switch (next to the Key Hole) is a number (very small) you may need a glass to see it. If you can read it you can get a replacement.
Also Johnson/Evenrude dealers may have a key ring with all the keys, that is a last resort.
I replaced the switch, took all of about 30 min and cost me 33 bucks, the key, if you can find it, is about 15 bucks
you can start it if you disconnect the large red harness connection,and jump directly to the starter,but,you wont be able to shut it down unless you use the manual choke,its a dangerous ,thing to do ,but can be done if necessary,as suggested look for that number,its likely a 2 digit number on the side of the slot key goes in,unfortunatly the numbers often wear off,magnifying glass may help
A "real" locksmith can make you a key from the code. Problem is, "real" locksmiths are hard to find these days. The kid at Walgreens isn't a locksmith.
