Might have figured out my stalling
199675hpforce
Ok checking the fuel recovery system looks like my little hoses are cracked pretty good. Anyone know the dia size if I run down hose place? Looks to be 1/4 or maybe 1/8th. Looked up diagram at crowleymarine shows it being same size regular tubing? Could this be cause of stalling? Im thinking it could by allowing air into the system.
http://www.crowleymarine.com/mercury-outboard/parts/2014_5.cfm
pnwboat
Re: Might have figured out my stalling
Also check the fittings that the hoses connect to. Some are straight through, some are one way check valves. Sometimes they get gunked up. Not sure about the size. Just take a piece of it with you and they should be able to match it up.
