88 Force 85hp o/b - no start & no trim/tilt
b_boudet
88 Bayliner with 88 Force 85hp o/b motor.
She ran fine last year, except the last time I was out it overheated... new water pump needed I think. So this year I got the parts to do the water pump, and lo and behold I can't get the motor to tilt down, just a click when I push the switch. So I turned the key just to see if she'd start, and again just a click. As far as I can tell the battery is good. So I removed the trim relays and connected the blue and green wires directly to battery, one at a time while grounding the other - nothing but a little spark and a little smoke, no motor noise, no nothing. So then I connected the starter directly to battery - nothing but a little spark, no starter noise, no movement. I thought maybe the neutral switch, so I bypassed that - no change. I thought maybe the emergency shutdown switch, so I bypassed that - no change.
What could this be? A bad starter and tilt motor at the same time seems a bit far fetched. And I don't want to start replacing expensive parts until I'm pretty sure that is what's wrong. Am I just missing something obvious here? I'm new to this o/b maintenance thing, so any help/ideas would be greatly appreciated.
my1stboat1
Re: 88 Force 85hp o/b - no start & no trim/tilt
you said from what you can tell the battery is good... Why not test it and before instead of troubleshooting the 3 other items you just tried to make work and all didnt from the same battery .... I dont know Just an idea !!!!!
further
+1:)
b_boudet
Sorry, guess I did not word that well. Battery is good, good voltage at battery, good voltage in numerous locations around engine, even tried with another battery and same result.
Any thoughts? Thanks.
further
Check all your wiring and connections for dirt/ corrosion or loose connections.
b_boudet
Will do. But if I hook up the starter directly to 12v power and it doesn't do anything... does that definitely mean the starter is dead?
Thanks.
