Need prop change
jcupo6
I recently changed motors. The boat had a 140hp mercruiser with a cracked block. I replaced it with a 120hp merc but kept the same prop, couldn't afford to purchase a new one at the time. I'm ready now!
1. Looking for a good overall prop to gain some speed and rpms. I mainly use the boat for fishing, but might pull a tube here and there.
2. Currently the boat has a 19 pitch aluminum merc prop. Sorry, I'm not sure what model. It's pretty old but in good condition, maybe a black max?
3. The boat currently tops out between 26-30 mph at 2900-3000 rpm with an average load. She should be running around 3800-4400 rpms.
4. Engine is a 1978-1982 120hp merc with a 1 year old SEI drive.
5. Boat is a Aluminum 22 foot 1973 Starcraft Holiday. With no fuel, gear, or passengers the boat weighs around 1600 pounds. I usually run with 1-2 passengers.
Since the current prop was installed for the 140hp motor, I assume I can get more rpm's and speed with a prop change. Thanks in advance for your help!
jcupo6
Re: Need prop change
I would also like your opinions on aluminum vs stainless props. I generally do all my boating in the Delaware bay, not in waters with rock bottoms.
jdub2
Assuming the engine is in top running condition, I'd go down in pitch. Maybe to a 15" pitch. Should gain, in theory, around 800rpm (200 rpm increase per inch of pitch decrease)
