Early 1970's Ouachita 12' aluminum boat restoration
Cheapshot
Hello,
I have been working on a 12' Ouachita boat due to some problems that it has. I have some pictures I will post in order so you all can see what I am dealing with.
To start out with I was given this boat by my parents. They got it from my Grandfather who passed away more than a year ago. I trailored the boat over 800 miles to Missouri and parked it in my back yard. Last fall I began the tedious work of getting this thing back up to par and still have not finished it. The boat had a 4 inch crack in the center of the hull and it leaked water faster than you could bail it out. The hideous blue paint was flaking off and revealing 3 other coats of paint. A thick silver aluminum roof paint below the ugly blue, another coat of gray paint and a coat of blue primer. The original Ouachita decals on the sides were almost completely faded.
I first began with laying tracing paper over the decals and got a pretty good reproduction of the original decals. I scanned those tracings into my computer then cleaned up the lines with MS paint. I will eventually take those to a sign / sticker company and have them remake the decals to the correct dimensions for me.
I began stripping the paint off the boat by using aircraft stripper, a putty knife, a razor blade scraper and a drill with a wire brush. After I had most of the paint stripped off the boat I took it to a welding shop and had the crack welded shut. Once I got it home I began removing the completely rotten transom board with one hand.
It never dawned on me before, but when I was removing the bolts from the handles that were bolted to the aft they were completely rusted. Once I got the transom board out and started grinding the paint away I could see the aluminum transom was corroded badly in spots do to two different metals contacting each other over the years along with exposure to water.
So now I am at a stand still with need of advice. I had two options in mind, #1 mix up some JB Weld and smooth over the inside of the transom. #2 take the boat back to the weld shop and have an entirely new piece of aluminum plate welded over the outside of the aft. Any suggestions would be greatly appreciated.
I will add a replay with an additional 5 pictures.
Cheapshot
Re: Early 1970's Ouachita 12' aluminum boat restoration
Next 5 photos
Cheapshot
Last photo
Huron Angler
Nice rig...looks alot like my 12' AeroCraft:)
I'd go the JB weld route on the transom skin. The welding probably adds up and this is a chance to cut your costs a bit.
Many folks have used JB weld for similar holes successfully. That is a nice hull design, I especially like how the bilge drain hole is so low it sits in the little dip in the hull.
If you haven't found out yet...Gluvit will be the choice sealer to keep those rivets and seams from leaking for years to come. A 2lb kit will be plenty for this boat and another of equal size, available here from iboats.
Good luck and keep posting photos/questions when ya have some!
Cheapshot
Thanks for the advice Huron, I'll keep that in mind.
