I started a new thread on this one since the problem is different.
I have a tilt/trim from a 1974 75HP I am retrofitting to my 1972 85HP. I got the motor and valve body back together and the reservoir is bolted to the transom. I did this while the bottom mount bolt was just through the port side transom bracket and the tilt assist shock. I could not get the starboard side of the trim ram body positioned to get the mount bolt all the way through. So I pulled the bolt out and put it through the starboard side but now the port side won't line up. It turns out that there needs to be about 3/16" to about a 1/4" more room.
Here is the question: Do I have to use a piece of aluminum angle or U channel to go the entire height of the transom bracket or can I just remove the lower bolts and use stainless fender washers to give me the space? If I want to take the bolts completely out I will have to pull the fuel tank because the nut inside the transom is behind it and I don't have the space to get a wrench and my fat hand behind it.
I was thinking I could take a piece of aluminum angle and notch it to make way for the bolt and then push it between the bracket and transom while loosening the bolts one side at a time which hopefully will keep enough tension on the nut that I don't have to pull the fuel tank.
I'm done for the night and I'm going to have 2 beers which is all I'm allowed otherwise I'll go hypoglycemic. I'm alone tonight so that's a no-no.
Thoughts?
Thoughts?
