regency 22ft pontoon with 115 hp motor speed
lakegeorge
Does anyone have the Tracker Regency with 115 hp motor? I am interested in the top speed of this set-up.
The dealers can't give me a specific number.
nikogto
Re: regency 22ft pontoon with 115 hp motor speed
25 mph is probably a good guess, depending on how many people are on board and extra weight and water conditions. Possibly a bit faster.
Water logged
If you have the performance toons with lifting strakes you should be able to do over 30mph. I haven't checked mine with gps, but the dealer said they took it for a test and hit 35 with low fuel and light load. Will try it later this summer myself. I know when it gets up on the strakes you can feel it pick up speed.:) Just curious, what prop do you have? Mine is a 13.75 / 15 and it hits 6600 at wot.
Glenn
Dkrager
Glenn
6600 RPM on a 4 stroke!!!:eek: I think that's a little high. I would guess 5500 should be WOT. Do you know what your motor is rated at?
kentuckyguy
I would think he could get more then 25mph.. I have a 21 foot Triton with a 90 hp.. With me and the wife, I get 27-28 mph on the gps..
oldjeep
Specs say WOT is 5800-6400 for a 4 stroke 115HP
To the OP, your speed seems slow. For comparison, my dads 21 ft SunTracker FishinBarge does just under 20MPH with a couple people on it and a 2 stroke 50HP
lakegeorge
waterlogged,
at present i have a 22 Sweetwater with 60 Yamaha.
There was a Regency next to mee for a few weeks at our dock but he had the 60 on his.
I may be interested in one next year, however I want something that i can cruise with at 24/25 mph. If 35 is tops then that would be great.
I will pm you
Water logged
Yeh the WOT max is 6400. I would like to get it closer to 6200. I would need 16 or 17 pitch to do that, but I haven't seen one in a 13.75 Dia.prop.
Glenn
lakegeorge
Waterlogged,
I emailed 3 dealers and they really didn't know how fast this boat should run. They guessed 22/26 mph, heck I get 21.2 on gps on my 22Sweetwater with 60 Yamaha, I would surely think with double the hp that I would gain more than 3 or 4 mph.
How can you sell a boat and not know what it will do on the water?
Mr Crabbs
Lots and lots of variables. Wind, water conditions, load, load distribution, condition of the logs and certainly other items I can't think of.
For example, we were out yesterday and I had to push the throttle up a touch after I turned into the wind in the NW zone.
I'm still breaking in our 90HP Merc 4 stroke, WOT is between 5K and 6K. On the GPS we were doing 23 into a brisk wind, bimini open, 690 pounds of passengers + gear, + 3/4 tank of gas, about 30 gallons. DW and her buddy were on the front couches, I had it opened up only to 5.4K rpm, probably had a little more in it.
jbail4032
I'm assuming yours is w/o lifting strakes? My 22 Regency has the strakes and a 135 HP Optimax and I get 30-40MPH range depending on the load.
