RDS 20 impeller kit
tim thompson
I boat has impeller but doesn't offer kit. Does anyone know where to find the full kit. It seems senseless to replace impeller without seals etc... also manual needed. Please help so I can mechanic and get back to the water......
F_R
Re: RDS 20 impeller kit
Complete water pump is part number 379775. Any Evinrude dealer..
Daviet
I don't beleave they offer a complete kit for that engine, I can't find a part number, looks like you have to get seperate parts.
You might check out Ken Cook or E-bay for a manual.
tim thompson
Thanks I haven't had luck with evinrude/johnson dealer. Do you think I need the whole kit? Can I get to impeller without to much difficulty. I don't have a manual yet?????
samo_ott
Does the LU leak now? I usually just change the impeller. In fact will be doing so today on my FD-10. I'd only worry about one issue at a time.
tim thompson
Thanks Captain Steve , There is some oil leaking doesn't appear to be severe but I have not located exactly where its leaking. its my first time so Im not too sure what is inside. I ordered impeller so I will learn soon enough.
F_R
I have no idea whether or not you need a whole kit. I thought you asked for it. Do you need one?? Depends on how badly worn the pump housing is.
All the parts are avaible separately, EXCEPT possibly the pump housing. They say they are not going to be making any more aluminum housings. Still available in the kit though.
