???? Whats wrong?
henneberrya
1989 350 mercrusier alpha one
at half throttle before it makes it to plane, engine revs thrust is gone, pull back on throttle it reengages itself.
It feels likes it slips out of gear so it free spools, Pull the Throttle back it reengages itself without having to shift into neutral. No bad vibration or "cluck" it just looses drive ability.
Any thoughts or ideas of what the cause is? Or the damages i should expect?
Blk-n-Blu
Re: ???? Whats wrong?
Id be checking the prop hub. Possibly spun hub.
cr2k
Is this something that just started? Or did you buy the boat and it does this?
Sounds like either a prop hub or engine coupler. Change the prop and see if it makes a diff. If not could be the coupler that requires engine removal to replace the $300 part.
sdoomaha
Do you have a hydrofoil on it?
I purchased a boat that did the same exact thing. Swapped out 2 different props from the local dealer thinking spun prop hub. No help. Removed the StinkRay hydrofoil and the problem was gone. Went back to the original prop that came with the boat. With my hull design, the hydrofoil apparently took too much water away from the prop causing massive cavitation.
Good luck with your prob...hope it is a simple fix.
henneberrya
Thanks guys for the help and input
No it does not have a hydrofoil.
It is already in the mechanics shop. I just waiting to hear about the extent of the damages... I just have a feeling this is going to be pricey.
OldDriver
well BOAT does stand for "B"reak "O"ut "A"nother "T"housand! I'm looking at a little change outa pocket myself.:D
henneberrya
Well the marina says it was a spun hub. So its all fixed now.
Is there anything else i should be expecting to be going soon?
Yeah I this has happened during my 4th time out on the boat.. I had just bought it two weeks ago...
Blk-n-Blu
Quick out of the hole starts are hard on prop hubs and couplers. The coupler requires pulling the engine out.
Haut Medoc
I would take a good look at the u joint bellows....
If there is one part you want to replace before it goes bad, that is the one.....;)
