Bow Light Out
dforcinito
Seems like the Bow Light is not working, Stern light works fine. I just replaced the light bulb and have power coming out of the switch. I checked for power with a Test Light, I do not have power at the Bow Light fixture.
Anyone have any recommendations where to look/test next?
Is there a fuse box somewhere, or maybe an inline fuse?
2003 Aquasport Center Console 165 Osprey
Thanks Dave
JoLin
Re: Bow Light Out
Thanks Dave
Yes. Where it is, is anyone's guess. You need to trace the wiring from the switch. Hopefully it runs to a fuse block somewhere near the dash.
Good luck!
Re: Bow Light Out
A fuse is generally before the switch, not after it. Therefore, if you have power into and out of the switch, the problem is either the ground for the light or the hot wire leading to the light.
