I have a '59 Johnson QD-20 engine that I recently just did some maintenance on. I replaced all the ignition parts (had one cylinder that was not firing at all).
While running the motor in a tub I noticed that the shaft seemed to get quite hot, yes I know that's where the exhaust is, and that there was no water coming out. Should this motor have a "pee" hole or have water come out with the exhaust?
I'm going to pull the lower off and replace the impeller, don't know if that has ever been done. Any tips on making sure everything is sealed up correctly?
Thanks
Thanks
