Ok this is my first post. I need help with an engine problem. I have a 165 mercruiser it begins to back fire and loss of power after about 45 minutes of running. It will start up and run great for about 45 minutes. I have had the carb rebuilt 2 months ago the guy used an automotive rebuild kit. I have replaced the coil (automotive coil and, automotive points). I was thinking it was vapor locking on me and I discovered it has a water cooled fuel line installed. I read in a service bulletin that this was a sollution to vapor locking on these engines so I hooked that up and it seemed to help but I still have the same problem. If I take the hood off the engine it seems to run fine. I still have a full tank of fuel but I know it is old even though I fill the tank every time I try to take it back out to see if I have it fixed yet. Maybe has 10 gal of fresh gas in. I was thinking maybe fuel pump but it read 7 pounds of pressure when I checked that. Any one with any ideas of what to try next?
Asa
Asa
