93 150 GLETR Fast strike....rebuilding the carbs and I have a few questions. Motor was surging at wide open throttle and would sometimes die at idle. Figured a rebuild wouldn't hurt. Thanks for any help you can offer!!!
1. Do I need to take the throttle body off or just the plastic carb?
I left the metal throttle body on there and removed the plastic carbs and these things are spotless. I'm going to go ahead and spray carb cleaner through it. Run a wire through the jets, and then blow out with air. Is this enough? I don't plan on knocking out the welsh plugs from the throttle body.
2. Any tricks to setting the float height?
