Hello Everyone,
First time poster here. Been lurking for awhile and now I need advise. Here is a little background. 1990 Hardin Marine Tahiti/Carabiean. Merc 260 Alpha 1 gen 1. I've had the boat for 19 years problem free. Appears that I've had a bad ujoint bellow for a long time. Followed all of your proceedures on getting things off and cleaned, painted and replaced, bellows, gimble bearing, shift cable & bushings, u joints ect (thank you) While I was doing the u joints I found that yoke shaft is a bit worn. should this be replaced? also found that the water was passing the seal on the upper outdrive. The bearings look like they got very hot. see pic. should these be replaced? also some of the spacers cracked in half?? looks like I will have to replace those. I will replace the seal and oring on the inner drive yoke and there is one other seal down in the upper housing under the drive shaft/bearing. how does one get that out??
Sorry for a first long post.. you guys have been a great help.
Thanks
Erik
Thanks
Erik
