Fresh water cooling?
Jim Marshall
I have an older Ford 302 that I was contemplating adding fresh water cooling. I noticed when I rebuilt everything that there was a lot of rust on the interior and water pump. I suspect it is from the process of going from wet to dry when draining it. I run occasionally in salt water making sure to flush it out. I can also see advantage in not having to drain the engine.
I was wondering what the advantages are and if it is worth the effort? Are the conversion kits adequate?
Jim
Haut Medoc
Re: Fresh water cooling?
Your engine is is too old for a coversion.....
The spec for that is 100 hours or one year, I believe.....
Internal corrosion will clog the heat exchanger.....;)
Jim Marshall
Haut Medoc.
I had the engine rebuilt and I believe they "boiled" the block and heads out. I am replacing the water pump with a new one. I scoured out the inside of the thermostat housing. The only thing that has not been cleaned is the exhaust manifold which I believe still circulates raw water.
I can see what you mean about the age and internal condition. Would this still hold with a rebuilding as described?
Jim
LAC_STS
I just bought a new 5.7 engine and was wanting to put freshwater cooling on it.
I was told by two different people/marinas that if your boat gets the raw water from the outdrive you shouldnt do it. They said onlyengines that have a raw water pump on the engine should.
I dont know if this is bs or not because I see kits designed especially for my setup. 5.7 OMC Cobra.
Just something to think about.
Jim Marshall
Mine has the water pump on the engine. I agree with you, why would it make a difference?
Jim
LAC_STS
They told me that the out drive pump doesn't supply enough water or something like that.
I see half and full systems for my exact setup though so I dunno. Maybe I just caught 2 people that theyre opinion is its not good although you can do it.
I would really like to know because I have anew engine and run 100% in salt water.
