I replaced my complete lower unit with a SE405 after market lower unit from
http://www.sterndrive.cc/mm5/merchant.mvc?Screen=CTGY&Store_Code=SE&Category_Code=SE405
After replacing the lower unit I took the boat for a test ride. Starting out at about 3000rpm slowly increasing 200rpm's until I reached full throttle. After a few times around the lake my warning alarm went off. I immediately put the boat in natural then pushed the button so I could increase the RPM to pumped higher volume of water a few sec after that the alarm silenced. I also checked both of my oil reservoir to insure they were full. I then again proceeded down the lake with caution working my way back up to 4600rpm (Full throttle) it seemed to be fine until I turned and the alarm went off. I again immediately went to natural and slightly increased throttle to increase water flow and it silenced the alarm.
Took the boat home and dropped the lower unit and checked the following items
Intakes: No obstruction could be found
Water pump: Removed the top housing to ensure water impeller looked fine and was not just spinning on the drive shaft.
Thermostats: Test both thermostats to ensure they begin to open at 50C.
I have also contacted SEI (who I bought it from) and they suggest that I remove the water pump and compare all the part to my original one.
I am very confused at this point because I did not have any cooling issues prior to replacing the lower unit.
Thoughts /Suggestions?
