what grade oil for my 151c 4cyl
bigbad 4cyl x2
looking for some good oil for my 151c 4cyl, i live in the bay area calif .i see some say there for sterndrives especialy by quicksilver .any help
PiratePast40
Re: what grade oil for my 151c 4cyl
If it's the 290 outdrive then the manual calls for SAE 10W-30.
bigbad 4cyl x2
yes it is a 290 ,im looking for engine oil
Robj
I've been running Royal Purple synthetic 15W40 in my AQ 131. Nice thing about the Royal Purple is that it is purple in color and if you have any engine leaks you can spot them easily.
A 30W or 40W would be fine as well, or even the Quicksilver 24W40. Do a search and you will be reading for days.
Oh no, another oil thread.
Have a great day
Rob.
HT32BSX115
Yeah.....
if you don't want to use what Volvo suggests using......you can really use whatever you want.
Just about every oil out there in radio land has been used successfully!
Regards,
Rick
sethjon
Engine oil? Use 10/40. And get only a top brand.
HT32BSX115
Use 10/40
Yes, but only if it's a synthetic.
Non-synthetic 10W40 has the highest amount of VI improvers compared to the others (10w30, 5w20, etc)
For that reason FOMOCO said they would VOID the warranty if it was used in my 86 6.9L diesel. (the owners manual indicated that it "may cause engine damage")
In the 90's Consumer reports indicated that 10w40 should not be used because it didn't stay in grade as well as the others.
(synthetic 0w40, 5w40, 10w40, 20w40 doesn't count since they don't use VI improvers [the entire oil is a "vi-improver"]......that's one of the advantages of using synthetic oil)
In fact, if you compare [SYN]0w30 and straight SAE 30, the viscosity at 100*C IS THE SAME. That's where it counts! not at cold temps. ...........(does anyone boat in -30F weather where you would need a synthetic multigrade oil?..........wouldn't the block be frozen solid?.....jeeze, wouldn't the whole frakken lake be frozen SOLID?
Now, having said all of the above, every oil known to Man (& Women:p) has been used successfully.
Use whatever is on sale at Wallyworld. (I wouldn't use "Non-Syn" 10w40 in ANYTHING!:rolleyes:)
Cheers,
Rick
bigbad 4cyl x2
the quicksilver at west marine was a synthetic blend but did say designed for stern drives . i almost grabbed it . ive had real good luck with royal purple in a Porsche i used to rally . if its marine compatible [i don't know if i needs to be] id like the royal purple
IES99
"every oil known to Man (& Woman) has been used successfully"
:D
robjen1019
I always used 30w in my sp volvo drive. Remember the single prop volvo outdrives use engine oil, and not gear lube. Only the duoprop drives use gear lube. So you are looking for a Marine engine oil. I always used amsoil in mine, but a friend of mine has used the cheep stuff at fleet farm for 10 years and never had a problem.
bigbad 4cyl x2
here is the pm i sent you robyjen ...................hello ,i own a sun-runner 195 b and ive completely restored it, when i restored it i repainted it and got rid of the sticker that shows weight capacity and maximum engine size .well now i realize i need that sticker so ill need to have a plate made showing those things . could you please tell me what your sticker says for weight capacity and for engine size capacity . maybe even a picture i would really appreciate it.
robjen1019
Sorry, Just pm you back. I have pic ready to send
bigbad 4cyl x2
thanks a million Ive been trying to get that info for over 3 years ,and 1 year from you .thanks again you made my day
