'88 Johnson 25hp Lower unit removal
ksbowhunter6
I have just bought a J25RCCA and i can't get the lower unit off. I have taken the 4 bolts out and also the nut off too. Its has never been off by the looks of it and i have only a small gap in the back, like i could slide a piece of card stock paper in and in the front of the lower unit there is no gap. Do i have to take the power head off or undo the shift rod down at the bottom?
Hope this is enough info for you all.
234rick
Re: '88 Johnson 25hp Lower unit removal
You have to remove the water intake screens then unscrew the brass nuts & slid up the top one so you can remove the split plastic ferrule. Leave a couple of bolts in the unit to keep it from sliding off.
Vic.S
As above to disconnect the shift rod but from what you say I suspect the stud, from which you removed the nut, is being held by corrosion etc round it. A bit of gentle heating and some release oil might help.
ksbowhunter6
I beleive you are corrrect. i think its the stud thats holding this all on too.
ksbowhunter6
I have heated the stud up with a butane torch and have sprayed penitrating lube on it and have been using a piece of wood and a hammer and still not moving. It has never been off before either.... what else is there to do?
ksbowhunter6
I still cant get this darn thing off. any other tips?
