The other day I slowed down in a congested area and happened to look back and I had a trail of smoke behind me and bellowing out of the water. Motor seemed to be running fine before this. Not sure how long it has been smoking like this. I was probably running 3500-4000 rpms at the time. I shut it down and haven't run it anymore.
The gap at the oil pump is 0.015 with the throttle linkages disconnect but it seems to be burning more oil than it should. I've gone thru 2 gallons faster than usual I think.
The O2 sensor was cleaned last year and I run Seafoam and StarTron religiously. Will a faulty or dirty O2 sensor cause this? Diaphams were changed last year also but that doesn't mean one isn't bad either. Warning buzzer is working when the kill switch is pulled. I did a compression check and within 5 psi over all cylinders with it cold.
Any ideas where to start? Could the seals (o-rings) at the back of the oil pump be bad allowing oil directly into the block? If so will I need to purge the oil system after reassembly?
