I have a 1976 Johnson 115 "sea horse". I'm at my ends with it.. Smash the throttle and will scat, runs great for about 15 seconds or so and then dies down and runs rough at slightly above idle with throttle still wide open. I can back off and let it idle a few minutes and can do it again. Otherwise it will not run consistantly unless I keep it under 1/3 throttle. Everything from the tank to the motor is new. Line, bulb, connections, pickup tube, etc. I've been into both carbs and are clean as a whistle and floats seem to be adjusted good. The guy I bought it from days it has a new fuel pump. I disconected the discharge of the pump and let it idle and it is pumping but I'm not sure if it's good enough. It seems I'm draining the carbs when running above 1/2 throttle. What am I missing?
