tperks7272
Thread starter- Joined
- Jun 1, 2009
- 2
Hi, I have been having a few problems with my 30 HP Evinrude motor. The first problem is while idling it will sometimes sputter once or twice and then go back to running normal. The second problem is sometimes when I will go to give the motor more throttle it will try to bog down and die. And the third problem has to do with the starter I think. The motor will crank just fine sometimes and other times I will have to take the motor cover off and tap on the starter to get it to engage otherwise I will just make a humming noise when I turn the key. So far I have cleaned the carb and added sea foam to the gas and also replaced the spark plugs. Does anybody have any ideas I can try? Thanks in advance.
