Ok so the rings are broken on #4 cylinder,no scars yet just small nicks on head, is it possible to replace piston without removing power head from lower unit?
65 psi compression 120/ 118/120 rest 1/2/3.
Thanks I was afraid of that,It,s been a while since I had her apart,the memory banks are a little slow thees days.
looks like a new piston Rings and a gasket set,
Also is the piston rod pressed in or c clips?
