steve bain
- Joined
- Jun 3, 2010
- 9
hey guys,
you were all so helpful and knowledgeable with my last question i thought i would ask again.
I have a 1990 ish mariner 150hp v6 carb.
wrong side, but may help a bit!
its all up and running and boy does it run!
i have been reading up and this is what i think it correct.
tan/blue wire which runs through the main harness and up through the tacho harness is for the auxiliary warning lamp.
the control has a built in buzzer, although i can't see one. its a quicksilver commander type think. but it must be in there somewhere.
the tan wire is for the sender to the water temp gauge. this is on the engine somewhere and not on the harness. any idea where on earth it would be? i run a seperate wire fo this to the gauge.
so. am i right in thinking once i find the tan wire i connect that to the gauge. the tan/blue i should wire into a lamp (my gauge has no warning lamp built in). when the lamp lights it means the engine is overheating.
I appreciate your time and help.
Regards, Steve
Regards, Steve
