autoblend removel
mrwrench
i have a 1988 merc 60hp and removed the auto blend,i replaced the fuel line from tank to motor,and on the wiring all i did was unplug the harness at the blender end and let it hang off the motor do i need to changing the wiring or will it run normaly with premixed gass ?
Faztbullet
Re: autoblend removel
Just trace it back under cowling and remove the wires as the purple is hot anytme engine switch is on.
