Volvo Outdrive Sags
maaraba
I have a 1990 Glastron with AQ131 C motor. The trim works fine but when I put the trim all th way up it begins to sag and eventually will go all the way down. Do I need to fill the trim motor oil? If so where is it.
Thanks?
Bifflefan
Re: Volvo Outdrive Sags
The seals in the rams or the in the pump are bad.
maaraba
is this somehting easily replacable? wher is the pump located? what can look for?
Thanks
