57sailplane
Thread starter- Joined
- Aug 1, 2010
- 31
i just got a 18 foot bluefin sportsmen i am redoing and pulled the whole floor out including foam and stringers.
what i found was 4 of the ribs have a crack were the the stringer is riveted to them. i am pretty sure this problem occurred from the trailer as the boat is not properly supported by it. most of the support is were these cracks occurred.
the ribs are half round with flange on both sides. the flanged areas are not cracked but the half moon areas are.
junking the boat is not an option. so how do i go about fixing? do i need to have these areas welded?
one other thing that came to mind is this boat has the usual ski storage area in the middle between the stringers. this was open. as i am planning to rebuild as a fishing boat i am planing on filling the center area with foam.. do you think this will help add strength to keep the ribs from cracking again.
thanks guys
later Andrew K
thanks guys
later Andrew K
